A solution to a 16-lane CSI-2 application
We are working with a mmwave radar sensor (TI AWR1243 transceiver).  Now we are evaluating base-band processor solutions. Xilinx Virtex 7 or Ultrascale+ FPGAs is a competitive choice for us. However, we get some confusions.
Each AWR1243 radar sensor has a CSI-2 V1.1 interface with 4 data lanes. We want to use a single base-band processor to handle the data generated by a 4-chip AWR1243 cascaded digital front end. I noticed that Virtex 7 and Ultrascale+ series FPGAs supply CSI-2 controller and D-PHY. But each CSI-2 controller support 4 data lanes. So if we choose one Xilinx FPGA as our processor, shall I just instance four CSI-2 controller IP cores and make corresponding IO selections to handle the 16-lane data from the 4 radar sensors?
Tags (2)
Re: A solution to a 16-lane CSI-2 application
Hi @yingliuysy,
Yes you can use 4 instances of the MIPI CSI2 RX IP to receive data from the 4 radars.
One comment on the device: I would recommend you to go for Ultrascale+ because it has a MIPI termination in the device. For Virtex-7, you would need to use an external phy as mentioned in xapp894.
Florent
Hi @yingliuysy,
Florent
Thank you for your reply. It helps a lot. I also notice that Ultrascale+ FPGAs have both D-PHY and CSI-2 controller. Virtex-7 FPGAs just supply CSI-2 controller. We will evaluate both Virtex Ultrascale+ and Virtex 7.
I still have another question. The 4 front end radar sensors need to be highly synchronized. If we use four CSI-2 controller to receive the 16-lane data, whether it will influence the system synchronization accuracy or not? Or some specific considerations should be taken?
Thank you.
HI @yingliuysy,
The D-PHY IP should available in both Virtex-7 and Ultrascale+ (in fact it is use by the MIPI CSI2 RX IP).
What I am talking is really the termination. Only Ultrascale+ devices have a MIPI_PHY_DCI termination on the IOs (refer to DS922)
About the synchronization, you will have to handle it in your code but it should be doable.
Florent
Hi @florentw,
I see the datasheet of XAPP894 and DS922. Maybe I get your point and I had some misunderstanding. So the main work of XAPP894 is to convert the FPGA I/O standard to comply with the D-PHY standard, right? And this is necessary for Virtex 7 FPGAs. If we choose Ultrascale+ FPGAs, the I/O banks can support D-PHY standard originally, as shown in the table. Both low power (LP) and high speed (HS) I/O standards are supported.
Regards.
Hi @yingliuysy,
Yes this is correct
Florent
