AXI Streaming Switch Tdata mismatch between CFA and v_vid
hi, folks
I have met an critical warning during connecting VFA and v_vid_in_axi4s:
CRITICAL WARNING: [BD 41-237] Bus Interface property TDATA_NUM_BYTES does not match between /v_cfa_0/video_in(1) and /v_vid_in_axi4s_0/video_out(2)
The CFA 's axis_tdata is always 8 bits width, and will not auto configured with external components.
Voyager
Voyager
Re: AXI Streaming Switch Tdata mismatch between CFA and v_vid
In PG002, the CFA does claim to auto-configure the Video Component Width.  What is the format and component width of the video output on the vid_in_axi4s?  Only a format of Mono and a component width of 8, 10 or 12 will work with the CFA.
Depending upon what version of Vivado you are using, there is also the Sensor Demosaic (v_demosaic) IP which is a newer implementation for Bayer conversion.
Ted Booth - Tech. Lead FPGA Design Engineer
https://www.designlinxhs.com
Voyager
Voyager
Thanks, ted.
The video out format is mono, and I made 2 pixels per cycle, so output width is 16 bits.
I don't think CFA can only support 8, 10 ,12 mode, that is too narrow for new high speed camera.
Vivado version is 2015.4.01.
I checked with demosaic, but my device (zynq-7000) is not availble.
@mcggoal
If the CFA can't do two bits per pixel, you can configure your Video In to AXI4-Stream IP for one bit per pixel, and use an AXI4-Stream Width Converter IP after the CFA to get your desired 16-bit 2bpp AXI stream, unless the 1bpp path won't meet your timing requirements.
Hi @mcggoal,
As @tedbooth correctly said, you might want to use the demosaic IP. It is available for Zynq-7000 but you might want to use a newer version of vivado (ideally 2018.1).
As said the CFA only supports 8,10 and 12 bits as per its Product Guide (you might want to read it for information):
And as @reaiken, the CFA does not support muliple ppc. This is why you cannot use it the way you are trying to. The warning is correct.
Florent
hi @florentw
Thank you for clarify, I think I have to walk around this.
Some still unclear, in the below topic:
https://forums.xilinx.com/xlnx/board/crawl_message?board.id=DEENBD&message.id=13200
I found the CFA was adapted to external interface to 16bits width.
Hi @mcggoal,
If everything is clear for you, please mark @tedbooth or @reaiken 's reply as accepted solution (select the best in your opinion - I only summurized their reply) by clicking on the button "accept as solution" on the bottom of the reply.
Thanks and Regards,
Florent
Hi @mcggoal,
You will get a width of 16 for tdata if the CFA is configured in 10 or 12 bits (as the AXI interface says the tdata width should be a number of byte).
You can do it automatically in your BD if you select MONO/SENSORS and 10 or 12 bits (with one ppc):
And after validation:
However if you try multiple ppc or 16 bpc you will get a critical warning or an error because this is not supported.
Florent
@florentw
Got ! thank you again!
