Advisor
Advisor
AXI4-Stream Quick Reference ?
Guys,
I am looking for a place that I can quickly learn the function of the I/O lines of the AXI4-Stream interface.  I am very familiar with flow control and digital signalling so I don't need a textbook, white paper or sales pitch.
Does anyone know of a quick reference document for AXI4-Stream that just lists the signals with their descriptions?
    Pete
DSP in hardware and software
Re: AXI4-Stream Quick Reference ?
Please check if the below links help
http://infocenter.arm.com/help/topic/com.arm.doc.dui0534b/DUI0534B_amba_4_axi4_protocol_assertions_ug.pdf
http://www.xilinx.com/support/documentation/ip_documentation/axi_ref_guide/latest/ug761_axi_reference_guide.pdf
Vanitha.
Advisor
Advisor
Those two references are almost completely fluff.
The best thing I found was the AXI4-Stream description in the FIR Compiler documentation, starting on page 18.
http://www.xilinx.com/support/documentation/ip_documentation/fir_compiler/v7_1/pg149-fir-compiler.pdf
  Pete
