About CSI-2 IntraLane mismatch
What's CSI-2 maximum mismatch between P/N for the lane ? Seems standard directly say about InterLane mismatch only ( < UI/50).
Tags (2)
Hello @olkhramus
MIPI D-PHY spec does not mention any restriction on Intra-Lane limitation.
But the spec define the worst-case of EyeDiagram that should be feed into RX receiver.
Please ensure your system can achieve this.
We have received similar question in the past. Xilinx suggest to make less than +/-2ps. See also UG583 Chapter 5.
Leo
Hello @olkhramus
Do you have any update on this ?
If you feel your questions already answered,
Please kindly marked this thread as Solved, so others can learn from your experience ?
Thanks & regards
Leo
