David5
About MIPI SoundWire & SLIMBus
We are trying to find some solution about MIPI SoundWire & SLIMBus.
But at Xilinx's website, there is no information about it.
 Is there any suggestion?
Can Xilinx device GPIO be compatible with the specification?
karnanl
Hello @David5
Yes, your understanding is correct.
At this point, Xilinx does not offer MIPI SoundWire/SLIMbus solution.
Most Xilinx device can support 1.2V 1.8V singe ended , bidirectional I/O, so perhaps SoundWire/SLIMbus is implementable, but I am afraid you need to check each device's datasheet yourself.
To be honest I am not familiar with these spec, so not sure if all electrical characteristic, timing budget can be met.
Leo
Versal Blogs
karnanl
Hello @David5
Leo
Versal Blogs
