Beginner Series 3 source files issue with Verilog build script
In the Beginner Series 3 code I am unable to successfully source the build verilog TCL in Vivado 2018.1 (I have also tried in 2018.2 with same result).
I get a critical warning
[filemgmt 20-2001] Source scanning failed (launch error) while processing fileset "sim_1" due to unrecoverable syntax error or design hierarchy issues. Recovering last known analysis of the source files.
The project looks like this
I have read that when you import the verilog source it will be classified as Non-module files if there is a compile problem.
Check-syntax does not indicate any error with the fileset.
check_syntax
INFO: [Vivado 12-4796] No errors or warning reported.
check_syntax -fileset sim_1
Attempting to run the simulation the tool will ask for a valid top module name.  It appears I do not have one.
Any suggestion to help me get going?  I think the VHDL version would work, but I would like to keep my environment in Verilog, as all my other code is in Verilog.
Thanks!
Hello @briankincaid,
This perhaps be related to an HSV/srcscanner issue, where scrscanner (HSV2.0) is having trouble running. I will send you privately some things to try out, that may be able to help you with this issue. I don't want to share this publicly, as this is wasn't tested fully and may not work for all users.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hi @briankincaid,
Did you made any modification to the verilog file?
I tried again the script and asked a colleague to try and it was successful in both cases (with different machine and OS)
I assume you already went through a first simulation as you have image_3.ppm already in your sources files. Is it correct?
Florent
Kind Regards,
Anatoli Curran,
Florent,
I tried unmodified, and also attempted to modify the tcl file but have the same result either way.
I did not go through the previous simulation.  I built this as a new project with your source.  I am using a fresh 2018.1 install.
I pulled the image_2 and image_3 files from the .zip and added them as sources.
Anatoli sent me some things to try so I will try those.  I am running on Windows 10 64b (home)
Best regards,
Brian (Daniel) Kincaid
