Boot from SD card does not works
Hi All,
I just following this tutorial  https://github.com/Xilinx/Embedded-Reference-Platforms-User-Guide/blob/2019.2/Docs/operating-instructions.md#511-single-sensor-setup
Using windows 10 machine,
Using See3Cam and HDMI monitor
After booting i gets following messages. I see blue screen on my HDMI display.
Hi @ok
Would you share result of these command on the console to investigate the route cause ?
ls -lA /usr/bin/
df -kT
Best regards,
Hi @watari
Please find the attached logs. I'm using workspaces\sd_card\stereo image in memory card.
See3Cam is connected in USB. HDMI out is connected to monitor
Ashok r
Hi @ok
According you shared log file (it's not my request...), the partition /dev/mmcblk0p1 is broken.
>[ 13.424684] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Starting udev
So, would you run fsck for /dev/mmcblk0p1 ?
Best regards,
HI @watari
I'm new to this, what is fsck and how i can run this?
Hi @ok
Refer the following step, if you can mount SD card on linux host.
1. unmount SD card on linux host (ex. umount <device name> (ex. umount /dev/mmcblk0p1)
2. run fsck command on linux host (ex. fsck /dev/mmcblk0p1 or fsck.vfat /dev/mmcblk0p1)
Refer the following step, if you can only prepare Windows host.
1. run cmd.exe as administrator privileges
2. chkdsk <drive name> on cmd.exe console (ex. chkdsk d:)
Would you try it ?
Best regards,
Thanks @watari  i will try it with my windows machine and update you.
Hi @watari
This is what i get.. after run
Hi @ok
OK.
ls -lA /usr/bin/
df -kT
These information is important to investigate the route cause.
Best regards,
Hi @watari
Please find the latest logs, in the endof log i have run those commands.
root@xilinx-zcu104-2019_2:/usr/bin# df -kT
Filesystem Type 1K-blocks Used Available Use% Mounted on
devtmpfs devtmpfs 684992 4 684988 1% /dev
tmpfs tmpfs 1022380 200 1022180 1% /run
tmpfs tmpfs 1022380 128 1022252 1% /var/volatile
/dev/mmcblk0p1 vfat 15549952 199840 15350112 2% /media/card
Thank you so much!
Ashok
