08-19-2020 02:33 PM - edited 08-19-2020 02:33 PM
When I use xlnx_pl_disp together with xlnx_vtc, I found the bug.
https://github.com/Xilinx/linux-xlnx/blob/master/drivers/gpu/drm/xlnx/xlnx_pl_disp.c#L575
should be replace with
ret = -EPROBE_DEFER; goto err_dma;
For dma acquirement in the next time probe, the acquired dma should be released in https://github.com/Xilinx/linux-xlnx/blob/master/drivers/gpu/drm/xlnx/xlnx_pl_disp.c#L549
08-24-2020 03:36 AM
Hi @hokim
Can you give some details about what failure you were getting and how this can be reproduced?
08-24-2020 05:29 PM - edited 08-24-2020 07:57 PM
I wrote linux drm encoder driver for hdmi of digilent's zybo z7 board
The below figure is vivado design which uses digilent's custom ips(axi_dynclk_0, rgb2dvi_0) for dynamic clocks generation and tmds signal generations
This is devicetree
/delete-node/ &misc_clk_0; &axi_dynclk_0 { compatible = "digilent,axi-dynclk"; #clock-cells = <0>; clocks = <&clkc 16>; }; &v_frmbuf_rd_0 { reset-gpios = <&gpio0 54 1>; }; &v_tc_0 { compatible = "xlnx,bridge-v-tc-6.1"; xlnx,pixels-per-clock = <1>; clocks = <&axi_dynclk_0>, <&clkc 15>; }; &amba { digilent_encoder { compatible = "digilent,drm-hdmi"; digilent,fmax = <150000>; digilent,edid-i2c = <&i2c0>; #address-cell = <1>; #size-cell = <0>; port@0 { reg = <0>; hdmi_encoder: endpoint { remote-endpoint = <&dmaengine_crtc>; }; }; }; drm-pl_disp-drv { compatible = "xlnx,pl-disp"; dmas = <&v_frmbuf_rd_0 0>; dma-names = "dma0"; xlnx,vformat = "BG24"; xlnx,bridge = <&v_tc_0>; #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; dmaengine_crtc: endpoint { remote-endpoint = <&hdmi_encoder>; }; }; }; };
When I used the original xlnx_pl_disp, it was not probed because it failed to request dma
xilinx-frmbuf 43c00000.v_frmbuf_rd: Xilinx AXI frmbuf DMA_MEM_TO_DEV xilinx-frmbuf 43c00000.v_frmbuf_rd: Xilinx AXI FrameBuffer Engine Driver Probed!! xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: failed to get video clk -517 xlnx-pl-disp amba:drm-pl_disp-drv: Didn't get vtc bridge instance xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: failed to get video clk -517 xlnx-pl-disp amba:drm-pl_disp-drv: failed to request dma channel xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: failed to get video clk -517 xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: failed to get video clk -517 digilent_drm_hdmi: loading out-of-tree module taints kernel. digilent-drm-hdmi amba:digilent_encoder: No max horizontal width in DT, using default 1920 digilent-drm-hdmi amba:digilent_encoder: No max vertical height in DT, using default 1080 digilent-drm-hdmi amba:digilent_encoder: Digilent HDMI DRM Driver probed 0 xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: failed to get video clk -517 xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: Xilinx VTC IP version : 0x0602000b xlnx,bridge-vtc 43c20000.v_tc: Xilinx VTC DRM Bridge driver probed
I could figure out that it was because the driver requested the acquired dma in the previous failed probe again through the following investigation
$ cat /sys/class/dma/dma1chan0/device/of_node/name v_frmbuf_rd $ cat /sys/class/dma/dma1chan0/in_use 1
I can fix it with my patch for xlnx_pl_disp which releases dma when it failed to probe due to deferred bridge vtc
The following shows successful log
xilinx-frmbuf 43c00000.v_frmbuf_rd: Xilinx AXI frmbuf DMA_MEM_TO_DEV xilinx-frmbuf 43c00000.v_frmbuf_rd: Xilinx AXI FrameBuffer Engine Driver Probed!! xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: failed to get video clk -517 xlnx-pl-disp amba:drm-pl_disp-drv: Didn't get vtc bridge instance xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: failed to get video clk -517 xlnx-pl-disp amba:drm-pl_disp-drv: Didn't get vtc bridge instance xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: failed to get video clk -517 xlnx-pl-disp amba:drm-pl_disp-drv: Didn't get vtc bridge instance xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: failed to get video clk -517 xlnx-pl-disp amba:drm-pl_disp-drv: Didn't get vtc bridge instance digilent_drm_hdmi: loading out-of-tree module taints kernel. digilent-drm-hdmi amba:digilent_encoder: No max horizontal width in DT, using default 1920 digilent-drm-hdmi amba:digilent_encoder: No max vertical height in DT, using default 1080 digilent-drm-hdmi amba:digilent_encoder: Digilent HDMI DRM Driver probed 0 xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: failed to get video clk -517 xlnx-pl-disp amba:drm-pl_disp-drv: Didn't get vtc bridge instance xlnx,bridge-vtc 43c20000.v_tc: vtc ppc = 1 xlnx,bridge-vtc 43c20000.v_tc: Xilinx VTC IP version : 0x0602000b xlnx,bridge-vtc 43c20000.v_tc: Xilinx VTC DRM Bridge driver probed [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [drm] No driver support for vblank timestamp query. xlnx-drm xlnx-drm.0: bound amba:drm-pl_disp-drv (ops 0xc073dad0) xlnx-drm xlnx-drm.0: bound amba:digilent_encoder (ops hdmi_drm_driver_exit [digilent_drm_hdmi]) Console: switching to colour frame buffer device 100x30 xlnx-pl-disp amba:drm-pl_disp-drv: fb0: frame buffer device [drm] Initialized xlnx 1.0.0 20130509 for amba:drm-pl_disp-drv on minor 0 xlnx-pl-disp amba:drm-pl_disp-drv: Xlnx PL display driver probed
09-03-2020 12:14 AM
Hi @hokim
Thank you for reporting this issue (with the fix) and for giving details on it.
I have sent the details to the SW developer, he has submitted the patch to be included in next release.
