ryant
CLB count to enable MIPI DPHY on Ultrascale+
I'd like to know how much CLB will be consumed when enabling and integrating MIPI DPHY on Ultrascale+ FPGA? The FPGA system will only has MIPI DSI, no CSI. MIPI host controller gate count and CPU core gate count will be estimated at my end. Preferably, I'd like to get the maximum gate count, up to to dual channels of 4 MIPI lanes each.
florentw
HI @ryant
If you check the IP facts table on the pg202 you will see a link to the Resource Utilization for MIPI D-PHY v4.2:
If you need more then just add the D-PHY 2 IPs to a design and run synthesis. This will give you the estimate
Florent
florentw
HI @ryant
Florent
florentw
HI @ryant
Is everything clear for you on this topic?
Florent
