saipradeep523
CSI-2 Rx Capture Pipeline integration with IIO framework drivers with ADI DMA instead of framebuffer write
I am working on the IMX274 Camera Sensor with MIPI CSI-2 Rx Pipeline as shown in the diagram. In the pipeline the FPGA IPs used is MIPI CSI-2 RX, demosaic , Gama, VPSS Scalar, VPSS CSC and Frame buffer write. my requirements demands IIO drivers integration with ADI DMA instead of Frame buffer write IP.
All these Xilinx FPGA IP drivers are registering with XVIPP driver, this driver is creating V4L- Sub devices video* and media device files  if the DMA is mapped in dts (If DMA field is not mapped it is not creating the all these device files). Driver path: drivers/media/platform/xilinx/xilinx-vipp.c and its dts is as follows:
vcap_gmsl {
compatible = "xlnx,video";
dmas = <&fb_wr_csi_0 0>;
dma-names = "port0";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
direction = "input";
vcap_gmsl_in0: endpoint {
remote-endpoint = <&v_scaler_0_out>;
Can we replace DMA filed 'dmas = <&fb_wr_csi_0 0>;' with ADI DMA. While i am doing experiments it is hanging.
ADI DMA dts:
axidma: axidma@0 {
#dma-cells = <0x1>;
compatible = "adi,axi-dmac-1.00.a";
reg = <0x0 0xb0040000 0x0 0x10000>;
interrupts = <0x0 90 0x4>;
clocks = <&axi_stream_clk>;
adi,channels {
#address-cells = <0x1>;
#size-cells = <0x0>;
dma-channel@0 {
reg = <0x0>;
adi,source-bus-width = <32>;
adi,source-bus-type = <1>;
adi,destination-bus-width = <64>;
adi,destination-bus-type = <0>;
adi,length-width = <24>;
Another Question is
2) I want to completely replace XVIPP driver with my own IIO driver wrapper on top of IIO driver. I experimented but in this case the v4l sub devices, video and media device files are not creating. is it possible to map data path at least?
florentw
Hi @saipradeep523
The AXI DMA does not handle the Video information (start of frame, end of line), so I am not sure how that would integrate with the driver.
What is the reason why you are not using the video frame buffer as DMA? This is, with the AXI VDMA, the only supported configuration by Xilinx
Florent
saipradeep523
My target is integration of  LIBIIO with capture pipeline either with ADI DMA or Video frame buffer as DMA.
