Gloria_gao
CSI2 RX IP constrain
I am trying to use IMX219 in TE0726-03M , so I create a block design and put zynq ip and csi-2_rx ip, which can be seen as below:
However, I feel confused about the pin constrains for csi2 rx ip, the csi connector in TE0726-03M is as followed:
There are two pins of CSI_D0 and i consider that the csi_d0 with R48 and R48 should be connected to data lane 0 in LP mode. I don't know whether it is correct.
Besides, there are no pins for clk and data 1 in LP mode, what should I constrain the clk and data in LP mode.
I try to connect both the LP mode and HS mode to the same pins with different electronic standards, but the errors appear up.
florentw
HI @Gloria_gao
I guess you can move forward with the progress from this topic right?
https://forums.xilinx.com/t5/Xilinx-IP-Catalog/cannot-find-csi-2-dphy-rx-ip-in-vivado2020-1-IP-catalog/m-p/1224628#M9838
florentw
HI @Gloria_gao
Gloria_gao
Yes, you're right.
Thank you again! ^_^
