watari
Professor
Professor
Can't download VCU TRD 2020.1
Hi all
I'd like to evaluate VCU with VCU TRD 2020.1.
However, because I got the following message I couldln't download it.
How do I fix it ?
The file you have requested is not available.
florentw
HI @watari
You were maybe too quick trying to download. It might take some time to have the files online.
Probably try again on monday. If that still does not work, let me know.
florentw
HI @watari
watari
Professor
Professor
Hi @florentw
Thank you for your explanation.
I already downloaded it.
I will try VCU TRD 2020.1.
