embedded
Advisor
Advisor
Can't file IP generated simulation files
Hi all,
I am using Video-In-2AXI IP block in a design. I was reading the datasheet and wondering where those generated test bench files are? I refer to PG043  Video In to AXI4-Stream v4.0 :
I couldn't find any of the above mentioned files. I will appreciate any help.
Hossein
florentw
HI @embedded
You need to find the correct timing information. One place you can look at is this page:
http://tinyvga.com/vga-timing
You can also find timings information in the Xilinx drivers (which can be used to program the VTC)
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/video_common/src/xvidc_timings_table.c
If you refer to the following, I am using the drivers to program the VTC (to support multiple resolutions):
Video Series 22: Supporting multiple video resolutions on ZC702 HDMI
florentw
Hi @embedded
It seems that these files are not generated anymore. I will have the PG updated accordingly.
I wrote a blog article you can use as reference for a simulation design:
Video Beginner Series 2: From Native video to AXI4-Stream
embedded
Advisor
Advisor
Hi @florentw,
I have tried them. But, I am using Vivado 2019.2 and I do not see the same signaling and timing that you have mentioned in these series. Could you please mention some links that have enough information regarding Hsync, Vsync positions in a line and clock frequency for various video formats? As I am using almost a new Vivado version I have to initialize those cores myself. Therefor, need to know such information to initialize the core accordingly.
Hossein
florentw
HI @embedded
