abstract
Cannot change VCU CORE Clk
I'd like to change the encoder clock of VCU (of ZynqMP). When I enter 333 as CORE Clk, then press OK, the console of Vivado shows the following error.
ERROR: [BD 41-245] set_property error - Validation failed for parameter 'Max Number of Encoder Streams(NO_OF_STREAMS) with value '0' for BD Cell 'vcu_0'. This configuration exceeds the VCU capabilities !
Customization errors found on 'vcu_0'. Restoring to previous valid configuration.
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
As a reference, I attach the image of the settings of another tab ('Basic Configuration').
I can change other settings (eg. Memory Resource Type) and then pressing "OK" doesn't complain. Also, when I select VCU, then change Block Properties > Properties tab > CONFIG > NO_OF_STREAMS to 1, the same error occurs where the value '0' is now '1'.
The version is 2019.1. Am I missing something obvious?
P.S.
I noticed increasing the clock frequency does not cause the problem. So the value 667 is the minimum value? The resolution of the image to the encoder is much lower than the displayed settings (nearly 4K and more). But I suspect just lowering the resolution in the dialog might cause problems in vcu driver on the Linux side (regarding memory allocation), I'd like to keep the resolution settings as is, just lowering the frequency (because the frame rate is below 10fps). Isn't that possible?
Update
Because the above method doesn't work now, I forced the PLL divisor to another value after PetaLinux boots.
# devmem 0xA0140030
0x0001021
# devmem 0xA0140030 32 0x00001041
# devmem 0xA0140030
0x0001041
Set ENC_CORE_CTRL (VCU_SLCR) register, DIVISOR0 value from 2 to 4. It seems the framerate is OK. But I still want to know the valid way to modify the clock.
florentw
HI @abstract
The encoder core clock is related to the resolution. If you decrease too much the clock then you might not be able to meet the requirements for the input stream.
I can decrease the core clock to 333 MHz if I reduce the size of the encoder stream to 1280x720 (1 stream) or if I change the input to 4K@15Hz .
So you need to make sure both configurations are coherent
Florent
florentw
HI @abstract
Florent
florentw
HI @abstract
Any update on this topic? Is the answer provided enough for you?
Florent
abstract
Hi @florentw ,
Thank you for answering. The encoder frequency I set by devmem command looks fine for my resolution/framerate, so I have stopped to seek the way to change the frequncy from Vivado GUI.
