jchewpoc
Confused on which VTC driver to use?
Hello Xilinx Forums,
I am trying to implement the master timing mode for the axis-2-vid IP. Where I have the VTC inline with a framebuffer read instead of the VDMA. I also have a mixer to stream out in place of the video processing block. Which vtc driver should I use to make this configuration?
From xilinx linux 2019.1:
1. linux-xlnx/drivers/gpu/drm/xlnx/xlnx_vtc.c
Compatible string: "xlnx,bridge-v-tc-6.1"
2. linux-xlnx/drivers/gpu/drm/xilinx/xilinx_vtc.c
Compatible string: "xlnx,v-tc-5.01.a"
Thank you.
jchewpoc
Hello @florentw ,
I was able to get the VTC driver to work using the DRM_XILINX driver with this VDMA stand alone configuration.
Thank you.
jchewpoc
Also, What is Xilinx's definition of "bridge"?
Thank you.
florentw
Hi @jchewpoc
I am not sure the VTC drivers can work in "standalone". The VTC is usually used inside another IP (HDMI, SDI...) or in addition of another IP (TPG). So I am not sure your use case is supported by the driver directly
Florent
jchewpoc
Hello @florentw ,
Thank you.
