tiger193
DDS Compiler v4.0 formula
 I have a question about the formula which is used to calculate the phase increment for a desired output frequency.
The Xilinx datasheet for the DDS Compiler v4.0 specifies different formulas.
http://www.xilinx.com/support/documentation/ip_documentation/dds_ds558.pdf
On page 3 a formula written on the left hand side below Figure 1 states:
f_out  =  phase_increment_value * f_clk / 2^B_capital_ Theta
   => formula (1)
   where   2^B_capital_ Theta  is the Lookup Table Depth
On the other hand on page 4 is written:
f_out  =  phase_increment_value * f_clk / 2^B_lowercase_Theta
   => formula (2)
   where B_lowercase_Theta is the Phase width.
From a logical standpoint I would guess that formula 1 is correct.
After some experimenting with SystemGenerator It seems as if formula (2) would be correct.
 Any comments about this?
Attachments: figure 1 from  Xilinx DDS  v4.0 Datasheet
eschei
Yes, you can use either formula, both are correct. However, if you use the upper case theta, refering to the post quantized B, the you will need to use a decimal at the corresponding position for your phase increment value. Since multiplying by a power of 2 corresponds to shifting the decimal position this will work out correctly.
example: say you want an fout of 5 MHz using a 100 MHz clock. Assume that you have a 31 bit accumulator and 14 bit look-up table address. You can calculate the phase increment value two ways:
5000000*(2^31)/100000000 = 1.073741824000000e+008
or
 5000000*(2^14)/100000000 =  8.192000000000001e+002
This is actually the same if we consider for the second equation a binary point at position 17 (31-14=17):
1.073741824000000e+008 * 2^-17 = 8.192000000000001e+002
-es
austin
t,
The phase increment is the width of the accumulator. If the accumulator is 16 bits, then the resolution (smallest frequency step) is 1/65536 of the clock frequency.
Perhaps the confusion here is 'width' and 'depth' of the lookup table. The address to the lookup table is the number of bits in the accumulator. Is that width, or depth? I would say depth, as that is the number of words in the table. The lookup table resolution could be the same as the address value (say 16 bits, and each addressed value returns 16 bits). The width of the lookup table provides the sine and cosine value to some resolution.
So, width of accumulator, depth of lookup table makes sense to me. Both formulas are correct.
Austin Lesea
Principal Engineer
Xilinx San Jose
eschei
or
-es
tiger193
Thanks a lot for your helpful replies. I gave both of you kudos :smileyhappy:
ywu
Strictly speaking the formula (1) wtih the capital Theta is incorrect because using the width of the quantizer output will not provide the same frequency resolution. I will file a change request to get it fixed.
   => formula (1)
   => formula (2)
Cheers,
Jim
tiger193
Hi Jim,
Cool that you initiated a action that will correct the documentation error.
Little Mistakes in the documentation can always happen, but as a customer it is good to know that even such small failures are corrected over time.  :smileyhappy:
