DP RX 1.4 Subsystem can generate bitstream with evaluation license ?
Dear all,
One of my customers want to evaluate the license EF-DP-DISPLAYPORT-SITE before buying it,
it's possible to generate the bitstream with the evaluation license ?
I know that he can use the DP Evaluation License for 120 days before it stops to work.
Thanks in advance.
Andrea
Re: DP RX 1.4 Subsystem can generate bitstream with evaluation license ?
Hi @andreac_avnet,
Yes. The evaluation license for DP allows bitstream generation. Note that there is an HW timeout in the core when using the HW evaluation license
Hi @andreac_avnet,
Thank you @florentw.
Andrea
