DPHY TX lane disable
We configured the mipi DPHY tx ip with 4 lanes.
In some configuration we need to use only one lane in HS mode.
When all the lanes are active everything is OK, but when some of the lanes are disabled the "ready" signal is never asserted again
after the first packet.
Is this behavior expected?
Marco
badbadgoodgood
Re: DPHY TX lane disable
Hello Marco @marcoventurini
Did you enable "Active lanes support" in the GUI ?
Did you set "active_lanes_in" when output is in LP-11 state ?
Thanks & regards
Leo
Thanks & regards
Leo
That was the problem, I overlooked this setting, sorry.
Thanks for your support.
Marco
