11-18-2020 03:28 AM - edited 11-18-2020 03:33 AM
I am using ULTRASCALE+ MPSOC which is xczu4ev-sfvc784-1-i family. I have camera which interface is LVCMOS and I want to capture live video.That's why I used DMA, DRAM IP cores. I can write and read data DRAM using AXI DMA. Moreover, I need to use GSTREAMER and unfortunately I cannot access the that video data by using GSTREAMER. How can I access the DRAM via GSTREAMER?
Can you help me?
Regards.
11-18-2020 02:07 PM
11-19-2020 12:02 AM - edited 11-19-2020 12:08 AM
Hi @watari,
I am using actually PS DRAM inside the ultrascale mpsoc and I don't know how I will intagrate gstreamer and memory together. I store the camera data in the memory which is ps dram and I want to send these data to gstreamer. How gstreamer access the these data ı dont have any idea about this issue. Also this capturing the video process is done on petalinux.
11-19-2020 07:59 PM
Hi @erdincc
Would you consider v4l2 on linux and v42l source element at GStreamer ?
How do you capture video stream ?
For example, if you captured video stream data by ex. yavta on petalinux, you already prepared v4l2 media graph.
