DRM Bridge driver
As stated in this link
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/160825371/Xilinx+DRM+VPSS+Scaler+driver
Does it mean, I can not use the DRM Bridge driver in between the FBRD and FBWR to store the processed frame into memory?
I have tried using this bridge driver, but when I echo the xlnx_bridge-vpss, the segmentation fault occurs.
Hi @peakpeak
Did you prepare proper DRM pipeline ?
It seems you need to consider v4l2 pipeline from previous your posts.
So, I suggest you to consider what you want to do via v4l2 and/or drm, again.
Best regards,
Hi @peakpeak
Best regards,
