DSP System Generator and RocketIO for fast serial Transmission
I'm now evaluating possibility to utilize RocketIO or GTP transceivers in system generator design.
Can somebody annswer me if it is possible to use GTP transceiver in System Generator only to transfer Data between FPGA chips without significant protocol overhead but on high speeds. E.g. only clock synchzronization 8B10B coding, and FEC. Is it possible to do only using System Generator Blocks?
I understood, that it necessary to provide high frequency clock for serial transmission, and it may be complex for sysgen, but maybe somebody tried...
Thank you.
