kailassenan
DVI/HDMI Video Receiver IP
Hello Xilinx rep,
When would be your release of DVI/HDMI Video Receiver IP (XAPP460 and design files)?
I required the core for designing the DVI Receiver in the Xilinx Reference Design  http://www.xilinx.com/support/documentation/application_notes/xapp928.pdf
Kindly let me know regarding this.
Kailas Senan
Message Edited by kailassenan on 07-25-2008 12:47 AM
bob.feng
http://www.xilinx.com/support/documentation/application_notes/xapp460.pdf
bob.feng
kailassenan
Hello Mr Bob Fen,
Thankyou for your reply.
Kailas Senan
Hello Bob,
I am evaluating DVI/HDMI Video Receiver IP and in this regard need clarification related to phasealigner.v.
Test Inputs: Test bench is driving TMDS_CLK clock at 74.25MHz and half clock data pattern is generated at a rate of 7.425 MHz.
From simulations I observe that, psaligned never gets set, as PSALGND state is never attained. Ultimately HSYNC, VSYNC and DE signals are been affected. Please let me know if I am wrong in driving clock or test pattern and suggest to clarify input conditions to set psaligned.
Ganesh.R
Hello! I downloaded the .pdf and reference files, but I'm unable to identify the spartan 3A TMDS evaluation and expansion boards shown at page 29.
Are them available for purchase and/or did you carry out your tests on another board?
Thanks a lot and Best Regards
Alessandro
dhinu1
Hello Bob,
I am pleased to see the reference design working in our boards. but i have a query regarding the reference designs whether the reference design works for all resolutions?
Because I am able to get Display control signals Hsnyc V Sync and Data en exactly for 40MHz Pixel clock. But as the Pixl clock increase to different resolutions say 110 Mhz pixel clock. the control signal are not generated.
I amusing SPARTAN 3AN FPGA: So please let me know if there are any customised Changes required in our Design. In the reference design the CLKIN period for the DCM is 13, so i assume  the  the expected Input frequency is around 70Mhz Pixel clock?? will it not work for other frequencies..
Thank you
Dhi
15071976
Dear Bob,
is a resolution of 1080p@50Hz/60Hz also possible with this design?
Bjoern Thomas
