DVI/ custom peripheral
I have got a ML605 Xilnx development board. I want to drive a monitor and an external custom peripheral. I'm looking for some posts  that will help me put these 2 things together. I've been build a system with a DDR3 implemented in PLB sytem, for the monitor controller I installed a TFT IP and all work perfect . My project requires a custom peripheral but when I add this new IP peripheral to the system the DDR3 stops to work. I tried to check using a C program in SDK but when it starts to run the DDR3 stops to work and I can't control the DVI output and also the custom peripheral registers.
Someone can help me? Thank you for your time, have a good day!
