Defective pixel correction
Is there any ip cores available in vivado that can do defective pixel correction?
florentw
HI anjumohan@cdac.in
In the Vitis Vision library there is a bad pixel correction block which can be used:
https://github.com/Xilinx/Vitis_Libraries/tree/master/vision/L1/examples/badpixelcorrection
You can implement it as a kernel in vitis or as a HLS IP in vivado
Florent
florentw
Florent
florentw
Hi anjumohan@cdac.in
Is everything clear for you on this?
Florent
Thank you for the solution....
