nishiuser
Delay in omxh265enc in 4K encoding
Working in Zynq UltraScale+ MPSoC
The output of following pipeline have frame skipping. When the same pipeline runs with h264 encoder, the output is smooth.
gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! video/x-raw, format=NV12, width=3840, height=2160, framerate=60/1 ! queue ! omxh265enc qp-mode=auto gop-mode=basic gop-length=60 b-frames=0 target-bitrate=10000 num-slices=8 control-rate=constant prefetch-buffer=true low-bandwidth=false filler-data=true cpb-size=1000 initial-delay=500 ! video/x-h265,profile=main ! queue ! h265parse ! matroskamux ! queue ! filesink location= test.mkv
By further debugging, I found that the time taken to encode one frame by the encoder is
h264 : 16ms
h265 : 95 to 100ms
The delay comes from some frame handling at the output port of encoder.
Any suggestions on how to resolve this ?
kvasantr
Hello @nishiuser
what is the version of SW you are using to run the above pipeline?
are you using TRD designs to test? if yes which one?
nishiuser
Gstreamer version :1.14.4
omx version : release-2019.2
I figured out the issue, but could not solve it.
gstomxvideoenc.c:2567:check_input_alignment:<omxh265enc-omxh265enc0>
input buffer has wrong size/stride (12441600 expected: 12533760), can't use dynamic allocation
h265 encoder expects buffer to be 32 bit aligned. So the input should be 3840x2176
But how can I achieve this ?
