Display Frame by frame by pressing button
Hi everyone,
I want to make a camera system by which I can get one frame output whenever I will press button. Actually, button will work as a trigger here. By enabling the trigger, I will have one frame output.
Right now I have this kind of setup.
From the figure you can see, by pressing the push_btn_r (green line), the interrupt will be enabled. And in the handler function, I make the reset '0' for the for the few moments. Here is the code:
void BTN_Intr_Handler(void *InstancePtr)
	// Disable GPIO interrupts
	XGpio_InterruptDisable(&BTNInst, BTN_INT);
	// Ignore additional button presses
	if ((XGpio_InterruptGetStatus(&BTNInst) & BTN_INT) !=BTN_INT) {
	return;
	btn_value = XGpio_DiscreteRead(&BTNInst, 1);
	// Increment counter based on button value
	// Reset if center button pressed
	if(btn_value != 0)
		led_data = 0;
		xil_printf("Led value =%d\r\n",led_data);
		XGpio_DiscreteWrite(&LEDInst, 1, led_data);
		for (int i=0; i<500000;i++);
		led_data = 1;
	else
		led_data = 1;
	(void) XGpio_InterruptClear(&BTNInst, BTN_INT);
	// Enable GPIO interrupts
	XGpio_InterruptEnable(&BTNInst, BTN_INT);
By pressing each button, I don?셳 have output right now. In my code, I gave a delay when a button is pressed. The delay is near about 100 ms. So that I can see the output for a moment. Sometimes, I have output sometimes I don?셳. Why is this happening?
Besides, my intention is by pressing button time I will see one frame output at the monitor until I press the button for the next time. How may I have this kind of system?
My design currently contains:
Sensor --> video_in --> VDMA --> video_processing IPs --> video_out --> HDMI
I am not expecting exact answer but any kind of suggestion will be very helpful.
Thank you
Rappy Saha
Re: Display Frame by frame by pressing button
@rappysaha you need to debounce the output of button properly before you use it as an interrupt source. Mechanical buttons behave in a funny way when pressed and released (you get many presses and releases with very short pulses etc) so you are really not getting anything meaningful right now. Clean up the button output and you will see more consistent results.
