RajuKoppada
Display issue on ZCU104
Hi Team,
Display is not coming up when I am trying to port "petalinux-user-image-zcu104-zynqmp-sd-20190802.img.gz"  image on to zcu104 platform.
I have checked the previous post  and I tried same modetest and I also faced same issue.
Note: In my case I have connected DP to HDMI converter to connect to display, because we don't have DP port display.
Here my modetest command console log.
modetest -M xlnx Encoders: id crtc type possible crtcs possible clones 38 0 TMDS 0x00000001 0x00000000 Connectors: id encoder status name size (mm) modes encoders 39 0 disconnected DP-1 0x0 0 38 props: 1 EDID: flags: immutable blob blobs: value: 2 DPMS: flags: enum enums: On=0 Standby=1 Suspend=2 Off=3 value: 3 5 link-status: flags: enum enums: Good=0 Bad=1 value: 0 6 non-desktop: flags: immutable range values: 0 1 value: 0 19 CRTC_ID: flags: object value: 0 40 sync: flags: range values: 0 1 value: 0 41 bpc: flags: enum enums: 6BPC=6 8BPC=8 10BPC=10 12BPC=12 value: 8 CRTCs: id fb pos size 37 0 (0,0) (0x0) 0 0 0 0 0 0 0 0 0 0 flags: ; type: props: 20 ACTIVE: flags: range values: 0 1 value: 0 21 MODE_ID: flags: blob blobs: value: 18 OUT_FENCE_PTR: flags: range values: 0 18446744073709551615 value: 0 30 output_color: flags: enum enums: rgb=0 ycrcb444=1 ycrcb422=2 yonly=3 value: 0 31 bg_c0: flags: range values: 0 4095 value: 0 32 bg_c1: flags: range values: 0 4095 value: 0 33 bg_c2: flags: range values: 0 4095 value: 0 Planes: id crtc fb CRTC x,y x,y gamma size possible crtcs 35 0 0 0,0 0,0 0 0x00000001 formats: VYUY UYVY YUYV YVYU YU16 YV16 YU24 YV24 NV16 NV61 GREY Y10 BG24 RG24 XB24 XR24 XB30 XR30 YU12 YV12 NV12 NV21 XV15 XV20 props: 7 type: flags: immutable enum enums: Overlay=0 Primary=1 Cursor=2 value: 0 16 FB_ID: flags: object value: 0 17 IN_FENCE_FD: flags: signed range values: -1 2147483647 value: -1 19 CRTC_ID: flags: object value: 0 12 CRTC_X: flags: signed range values: -2147483648 2147483647 value: 0 13 CRTC_Y: flags: signed range values: -2147483648 2147483647 value: 0 14 CRTC_W: flags: range values: 0 2147483647 value: 0 15 CRTC_H: flags: range values: 0 2147483647 value: 0 8 SRC_X: flags: range values: 0 4294967295 value: 0 9 SRC_Y: flags: range values: 0 4294967295 value: 0 10 SRC_W: flags: range values: 0 4294967295 value: 0 11 SRC_H: flags: range values: 0 4294967295 value: 0 34 tpg: flags: range values: 0 1 value: 0 36 0 0 0,0 0,0 0 0x00000001 formats: AB24 AR24 RA24 BA24 BG24 RG24 RA15 BA15 RA12 BA12 RG16 BG16 props: 7 type: flags: immutable enum enums: Overlay=0 Primary=1 Cursor=2 value: 1 16 FB_ID: flags: object value: 0 17 IN_FENCE_FD: flags: signed range values: -1 2147483647 value: -1 19 CRTC_ID: flags: object value: 0 12 CRTC_X: flags: signed range values: -2147483648 2147483647 value: 0 13 CRTC_Y: flags: signed range values: -2147483648 2147483647 value: 0 14 CRTC_W: flags: range values: 0 2147483647 value: 0 15 CRTC_H: flags: range values: 0 2147483647 value: 0 8 SRC_X: flags: range values: 0 4294967295 value: 0 9 SRC_Y: flags: range values: 0 4294967295 value: 0 10 SRC_W: flags: range values: 0 4294967295 value: 0 11 SRC_H: flags: range values: 0 4294967295 value: 0 28 alpha: flags: range values: 0 255 value: 255 29 g_alpha_en: flags: range values: 0 1 value: 1 Frame buffers: id size pitch
Can you please suggest me how to resolve this issue? Can't I use HDMI monitor ?
Thanks and Regards,
Raju
watari
Hi @RajuKoppada
Which type of adaptor are you using ? Active adaptor or passive adaptor ?
According to your log, it seems that you use a passive adaptor and you are facing EDID issue.
You can use HDMI monitor, If it can read EDID from monitor via proper adaptor.
Would you consider it ?
Best regards,
RajuKoppada
Hi @watari  Firstly Thanks for your reply,
I am sorry, I don't know about adaptors types and I am using following DP to HDMI Adaptor.
https://www.indiamart.com/proddetail/scm-cable-display-port-dp-male-to-hdmi-female-adapter-15168619230.html
So in this case do I need to use active adaptor? If you have any recommendation please point me .
Thanks and Regards,
Raju
watari
Hi @RajuKoppada
I can't confirm whether your adaptor is active adaptor or not.
Also, I guess that adaptor issue is one of root case.
At least, you must change your device from this adaptor to an other active adaptor or from HDMI monitor to DP monitor.
The best way is to change monitor from HDMI monitor to DP monitor.
Here is easy way to find active adaptor, if you accept resolution limitation. (Maximum resolution is FHD(1920x1080@60Hz) or UXGA(1600x1200@60Hz))
- Has two type output. (HDMI and VGA (analog RGB))
Would you find proper adaptor with this information ?
Best regards,
RajuKoppada
Thanks, @watari ,
When we connect DP port monitor and this issue has fixed and display is working fine.
Thanks and Regards,
Raju
