01-07-2020 11:58 PM
Hi, there
I want design a Dispaly port to MIPI CSI converter . I need some suggstion about the chip and the IP needed.
Henry
01-08-2020 04:30 AM
Hi @henryjsw
Do you want to build the following ?
DP Rx IP -> MIPI CSI Tx
I guess you want to build the following ???
DP Rx IP -> MIPI DSI Tx
01-08-2020 04:56 PM
I want :
Use vedio card as carmera input.
Henry
01-09-2020 01:41 PM
Hi @henryjsw
Refer the following URLs.
- DP Rx IP
- MIPI CSI2 Tx IP
- Product Discontinuation Notice for MIPI CSI2 Tx IP (But might be good news)
https://www.xilinx.com/support/documentation/customer_notices/XCN19027.pdf
01-10-2020 01:04 AM
@watari wrote:
Hi @henryjsw
[Florent] - This is indeed a good news for customer has the MIPI IPs will all be included in vivado for free (i.e. they will not require a license anymore)
02-04-2020 02:32 PM
Hi @henryjsw,
Were the responses from Watari and Florentw enough to answer your question?
If so, can you mark one of their solutions as accepted so that the thread is closed?
Thank you,
Sam
10-19-2020 10:56 AM
Hello @henryjsw ,
I am attempting to implement something similar. DP to MIPI-DSI. Did you figure out a solution for DP to CSI?
Pascal.
