DisplayPort 1.4 RX design example on zcu111
I've gone through creating the design example for a zcu102 in PG300. I currently have a zcu111 and am attempting to implement the design example on it. I don't seem to be able to add the IP to the block diagram as shown in PG300 in step 6 on page 70. I get the errors below, any thoughts on what the issue might be adding the IP or if it is possible to host this design example on a zcu111? I do have one of the Inrevium TB-FMCH-VFMC-DP daughter boards on order.
Best Regards,
larryhld
  • [Common 17-69] Command failed: Invalid site type qualifier 'GTHE4_CHANNEL' specified
  • [IP_Flow 19-3477] Update of parameter 'PARAM_VALUE.CHANNEL_ENABLE' failed for IP 'design_1_v_dp_rxss1_0_1/bd_2209/bd_2209_dp_0'. ERROR: [Common 17-69] Command failed: Invalid site type qualifier 'GTHE4_CHANNEL' specified
  • [IP_Flow 19-3428] Failed to create Customization object design_1_v_dp_rxss1_0_1/bd_2209/bd_2209_dp_0
  • [IP_Flow 19-5622] Failed to create IP instance 'bd_2209_dp_0'. Failed to customize IP instance 'bd_2209_dp_0'. Failed to load customization data
  • [BD 41-1712] Create IP failed with errors
  • [BD 5-7] Error: running create_bd_cell -vlnv xilinx.com:ip:displayport:8.1 -type ip -name dp .
Hi @larryhld
I can reproduce this issue with 2019.2 but not with 2020.1. So I would suggest you move to vivado 2020.1 to design your project.
Hi @larryhld
That worked for me as well, Thanks @florentw
