09-22-2020 04:23 AM
Dear colleagues,
in the Microblaze example code for the DisplayPort Rx Subsystem V2.1, there exists the following interrupt routine:
static void Dprx_InterruptHandlerVideo(void *InstancePtr)
Can anybody tell me which event(s) will cause this interrupt rotuine to be called?
Actually, I'm looking for a interrupt routine, which is called, whenever the DP-source changes any input parmaeters, like the color depth, color format, horizontal and vertical resolution, framerate, etc. I have seen that the interrupt routine above is called, whenever the source chnages the color depth. But to be sure if I can use this interupt function, I need to know all evetns which will trigger this interrupt routine.
Best regards
stgateizo
09-23-2020 01:04 AM
Hi @stgateizo
1) What is meant with the term "valid video frame" (see bit 6 of register 0x040)?
Please refer to the description in register 0x014 (interrupt mask):
2) According to the documentation, the interrupt routine "Dprx_InterruptHandlerVmChange()" is only called, when the horizontal or vertical resolution is changed, but I neede also to be informed, when the color depth (8,10,12bit), or the color format (RGB, YCbCr), or the when the framerate is changed...
You are right. I cross-checked with the development team and only the horizontal and vertical resolution are checked in the MSA. Thus it would not be the correct interrupt to watch for you.
At the moment I see more a chance to get this implemented by using the interrupt handler "Dprx_InterruptHandlerVideo()", since it is called every time when I change any video parameter, like the color format, color depth, framerate, or resoution, etc. But I'm not 100% sure if this is right way, and it depends what Xilinx means with the term "valid video frame" ?
I guess this is the right way. I do not think sync will change the color format, color depth, framerate, or resolution in a continuous stream. So they will probably stop the stream to change these settings then restart the stream so you will get a video valid interrupt.
This is of course not talking about the adaptive sync that some GPU support but which is not supported by Xilinx (AR#64732). (PS. I do not know exactly how adaptive sync is working in case you ask).
09-22-2020 06:16 AM
HI @stgateizo
Looking at the KC705 example, the Dprx_InterruptHandlerVideo interrupt handler is associated to the interrupt XDPRXSS_HANDLER_DP_VID_EVENT:
Which according to this file, is the interrupt related for the valid video event:
This will only be asserted when there is valid video. While the interrupt you are looking at is the Video mode change:
While the interrupt you are looking at might be more Dprx_InterruptHandlerVmChange.
With that said, probably the video link is stopped when there is a change. Thus you will also get the Dprx_InterruptHandlerVideo interrupt
09-22-2020 06:58 AM
Hello Florent,
thank you for this information. 2 Questions:
stgateizo
09-23-2020 01:04 AM
Hi @stgateizo
