10-19-2020 11:12 AM
I am attempting to implement a bridging solution for DisplayPort to MIPI-DSI. I found the following IP's:
DSI Transmiter: https://www.xilinx.com/support/documentation/ip_documentation/mipi_dsi_tx_subsystem/v2_1/pg238-mipi-dsi-tx.pdf
Here are my questions
1- Would it be possible to use these IP's to implement DP to DSI?
2- Are there any available designs doing this?
3- I am looking at the Zynq-7000 SoC because it supports both IP's and is affordable. Is that a good choice?
Pascal.
10-19-2020 02:29 PM
Hi @pascaldao
What is your target resolution ?
It depends on your requirement.
10-20-2020 12:34 AM
Hello @pascaldao
Just adding my two cents.
Yes you can you both IP to implement DisplayPort to MIPI DSI TX.
# For MIPI DSI TX reference design, please see PG232 Chapter 5.
You can configure the Example Design to target ZCU102,SP701 or VCK190.
All Example Design has MIPI CSI-2 RX --> MIPI DSI TX implementation.
Probably you can generate an Example Design for SP701 for a reference.
# Please notice that if your DSI panel needs DCS long packet support for register configuration,
You need to use MIPI DSI TX from Vivado 2019.2 or newer version.
Kind regards
Leo
10-20-2020 02:12 AM
Hi @pascaldao
One caution about displayport on Zynq-7000:
The displayport IP does not support all the Zynq-7000 devices. Only the ones with GTX (kintex-7 based fabric) are supported (i.e Z-7030, Z-7035, Z-7045, Z-7100).
Also with Zynq-7000 for MIPI you need to have an external phy as per xapp894. This is not required in UltraScale+.
Thus Zynq Ultrascale+ might be something to consider. There is an example design for Displayport RX (using an external FMC card) and another example for MIPI DSI (as @karnanl mentioned, also requiring a FMC card) both running on the ZCU102. So this gives a good starting point.
Of course this is more expensive. I am not in sales so not trying to have you buy the most expensive. I am just mentioning it because it should be faster to develop (so you might save some engineering resources).
10-20-2020 07:46 AM
Thanks for your reply. I would like to do 1080x2160@60Hz. I would also like to do dual MIPI, that is 2 displays at that resolution. Would that be possible on the zynq-7000?
Pascal.
10-20-2020 08:00 AM
Thanks a lot. This is valuable information. Currently I am setting up the display using short packets. Does the the IP support DCS short packets as well?
I also need to do DP to dual MIPI using MST, each display is 1080x2160 @60Hz. Can I implement that witih the Z-7030?
Pascal.
10-20-2020 08:36 AM
GTX is a gigabit transceiver correct? Could this be implemented on the low-cost z-7000 devices using an external IC? The Z-7030 is already started to get too expensive for our application.
Pascal.
10-20-2020 09:04 AM
Hi @pascaldao
Yes GTX is a gigabit transceiver. This is required for the Xilinx Displayport IP.
There might be external to do "Displayport to data lanes" ICs but I am not knowledgeable about this so you will have to look around.
10-20-2020 02:24 PM
Hi @pascaldao
I guess you can achieve what you want to do.
However, you must use HBR2 (5.4Gbps) x 4 lane on your device, if color format is RGB888.
Also, you might need to consider external retimer or redriver to correctly receive signals.
[FYI]
As @florentw mentioned before, you can refer display port example design for KC705.
10-20-2020 09:33 PM
Hello @pascaldao
Regarding MIPI DSI TX Subsystem IP.
Yes. This IP support DCS short write command also. Please see PG238 Chapter 1,2.
( DCS read command is not supported )
Leo
10-21-2020 06:37 AM
Thank you guys!
Very useful information. This was very helpful!
Pascal.
