jtx
Displayport 1.4 TX - Native interface - fastclock, vid_clk ratio.
I am implementing Displayport 1.4 TX , Native interface w/4ppc on a custom board  (w/Vivado 2019.2).
I have a question regarding use of the native interface. In PG299(v2.1) 14 May 22, 2019, page 58 :
‘Note: Data Valid might toggle if using a fast clock.’
I am getting image displayed on monitor when presenting an UHD@60Hz with a fast clock of 150MHz. The difference in clock ratios (150MHz(fast clock) and 133MHz(vid_clk)) is tuned by toggling the Data Valid within in the line/required timing).
When I try this for XGA(1024x768@60Hz->65MHz vid clk) resolution,  no image is presented on monitor. The VESA timing is (divided by 4) and ‘Data Valid’ toggled slower (evenly distributed) to compensate for the difference in ratio between the fast clock(150MHz) and vid_clk(16.25MHz). Are there any maximum ratio requirements between fast clock and vid_clk?
Thanks in advance.
watari
Hi @jtx
Would you make sure MVID and NVID value on DPCD to investigate this issue when video timing is XGA ?
Also, how many lanes is DP Tx using ?
It might be PLL issue...
Best regards,
florentw
Hi @jtx
The data valid can toggle during Vertical timing. However, it needs to remain stable during horizontal timing. As per pg299:
This means you can have lines with no data but you cannot have pixel clocks with no data during a line where you had data
I guess this might be something you want to check on your design.
Hope that helps
Florent
jtx
the used mode is asynchronous, so the M- and N-value is automatically computed by source and writtten to the mainstream. Use 4ppc/4 lanes in HBR2 at the moment.
watari
Hi @jtx
According your explanation, DP Tx will generate dummy packets to fill in the blank.
However, a few monitors can't accept like this situation.
Because they want to change lane number, if they don't have enough adjusment logic...
Would you make sure HPD signal, too, if possible ?
Best regards,
jtx
Hi @florentw
So the data_valid shall be conitinious over the horisontal resolution (line) of 1024pix/4ppc=256 clocks in 'XGA mode'?
Based on this the vid_clk must be exact the pix clock frequency described in XGA VESA format 65MH/4 =16.25MHz, to obtain the right timing.
Am I right or am I missing something here?
On page 63 of PG299(v2.1) Desember 2, 2019:
'vid_clk: This is the primary user interface clock. It is based on the DisplayPort Standard, the
video clock can be derived from the link clock using mvid and nvid. In addition, vid_clk
should be greater than to [(Vtotal x Htotal x frames per second)/pixels per clock]'
Is the vid_clk description not intended for Native mode configuration since it states that vid_clk should be greater than 'format pix_clk'/ppc ?
florentw
Hi @jtx
[Florent] -Yes this is correct.
[Florent] -Yes you are right
[Florent] - It should be greater or equal to [(Vtotal x Htotal x frames per second)/pixels per clock]. Small wording missing in the doc
Florent
jtx
Hi @florentw
[JTX] - If the vid_clk shall be be exact, how can it be greater? Should it only be equal in the statement above?
florentw
Hi @jtx
vid_clk can be equal OR greater than [(Vtotal x Htotal x frames per second)/pixels per clock].
But if it is greater, then you need to manage the stream to make sure the data enable does not toggle durring horizontal period as mentioned earlier.
If you want to feed a true video signal (without toggling data enable during active period) then you need to have the exact pixel clock/ppc
Florent
florentw
Hi @jtx
Do you have any update on this? Was my reply clear enough for you?
Thanks and Regards
Florent
jtx
it seems that lower resolutions are presented correctly on the monitor when the fast clock is not higher than about 5% than the expected video clock frequency (still toggeling data enable within the line to achieve the right timing).
samk
Hi @jtx,
It looks like you were able to find a solution. Do you mind selecting the best response from the thread as a solution so that if someone else has the same issue it is easier to find and also to close the thread for the community?
Thank you,
Sam
Xilinx Video Design Hub
