trenz-al
Displayport 1.4 in Vivado 2018.1 and MCDP6000
It seems that the Software libraries supplied with 2018.1 do not yet Support the new retimer MCDP6000 ?
When is more info about 8Gbit lane rate and MCDP6000 going to be released? The new Driver is in Xilinx github already..
Would MCDP6000 be usable/better with 5.4 G lane rate as well? Or is DP159 still recommended for lane rates below 8 ?
florentw
Hi @trenz-al,
Not sure why you are saying that the software librairies do not support the MCDP6000. I have it in my 2018.1 installation:
> I wouldn't say that it is better for 5.4G but you can definitely use it for all DP1.4 rates (1.62/2.7/5.4 and 8.1Gbps). We recommend to use it for new designs on US/US+. You can contact marketing for more details on which selection to do
Florent
florentw
Hi @trenz-al,
Florent
trenz-al
my fault, I looked at older Version of the Software library in the 2018.1 lib Folder tree. in Driver Version 5 they are indeed all included sorry for Panic :)
