yehuh
Dp 1.2 tx subsystem init failed
Plateform: XC7z035
Hello everyone,
As title, I can not initiate my dp subsystem. The SDK program would be stopped at Xil_DataAbortHandler().
Besides , I can't access the memory of  dp subsystem( BaseAddr to HighAddr).ps_mapping_mem_content.jpg
I'm sure that this is not the problem of the hardware, because when I switch to another "XC7z035", the problem remains.
Any comment would be appreciated.
yehuh
I should make clear that the version of the DisplayPort TX Subsystem I used is V2.1
Problem is solved.
At beginning. I use vivado 2018.3 to generate the hdf file, and SDK version is 2019.1.
When hdf file is generated by vivado 2019.1 => I can access the memory block and dp tx subsystem initiate successfully.
On the other hand, If I use vivado 2018.3 and SDK 2018.3 => dp tx subsystem initial failed.
yehuh
Problem is solved.
