01-10-2021 03:23 PM
01-14-2021 01:35 PM
Hi @joe306
>What if I only support one resolution that is most common on monitors, say 1920x1080p at 60Hz. Limits the monitors that you can connect to but still works.
I'm a little confusing.
As you mentioned before, you implement HDMI Tx. Not HDMI Rx.
So, your design (HDMI Tx) read EDID from target monitor via DDC/CI.
And bare metal software or kernel driver recognizes supported video timing and so on by reading EDID.
Best regards,
01-10-2021 08:18 PM
Hello @joe306 ,
The details of each parameter introduced in the EDID are clearly documented in the below link,
https://en.wikipedia.org/wiki/Extended_Display_Identification_Data
Hope this information is helpful to you. please let me know, if you have any questions.
Cheers,
Ashok.
01-12-2021 05:41 PM
In my application I am interfacing with a camera and I want to use HDMI to display the camera video. Is there some software that will generate the EDID data and then take the data and store it in the I2C EEPROM? This is my first time with HDMI.
Thank you
01-12-2021 08:35 PM
Hi @joe306
You don't need I2C EEPROM if you implement HDMI Tx,
However, you must read and parse EDID on HDMI monitor and decide output video timing with this information.
Best regards,
01-13-2021 06:58 AM
Hello, thank you very much for responding to my message. I am looking at the ZCU106 board as a reference and see they used a little EEPROM with an I2C interface. So, I ask on the ZCU106 board how does it read and parse the EDID? Is that done by reading a register in the SN65DP159 chip? By the way the VCK190 board has the same HDMI TX schematic as the ZCU106, the schematics for the VCK190 are easier to read (page 50).
Last, what is the purpose of the EEPROM? If I don't need it, do I see need to interface with the HDMI_CTL_SCL/SDA on the SN6a5DP159 device?
Thank you very much for your help.
Joe
01-13-2021 09:52 AM
Hello, let me run this lazy option by you. What if I only support one resolution that is most common on monitors, say 1920x1080p at 60Hz. Limits the monitors that you can connect to but still works.
Comments?
01-14-2021 01:27 PM
Hi @joe306
Refer the following URL. You can see the reason and so on.
As I already mentioned before, it's for ex. HDMI Rx and HDCP key.
Refer the above URL.
Best regards,
01-14-2021 01:35 PM
Hi @joe306
Best regards,
01-14-2021 02:57 PM
Hello, thank you for responding to my message. I'm clear now.
Thank you very much, Joe
