tcheeyon
Error generating Video Processing Subsystem on Block design
System:
Vivado 2018.1 on window 7 x64
Board:
Xilinx ultrascale+ ZCU106 evaluation board
Trying out:
http://www.wiki.xilinx.com/Zynq+UltraScale%EF%BC%8B+MPSoC+-+ZCU106+HDMI+Example+Design
I am trying out the above reference design for ZCU106. While executing the script (command "source zcu106_hdmi_ref.tcl"), an error due to the license with Video processing subsystem caused the script to terminate. I have set up the evaluation license for the video processing subsystem from https://www.xilinx.com/products/intellectual-property/video-processing-subsystem.html.
The problem is another error on the video processing subsystem appear. The error is shown below:
WARNING: [IP_Flow 19-2162] IP 'bd_e648_vsc_0' is locked:
* IP 'bd_e648_vsc_0' requires one or more mandatory licenses but no valid licenses were found. However license checkpoints may prevent use of this IP in some tool flows. Please select 'report IP status' from the 'tools/report' menu or run Tcl command 'report_ip_status' for more information.
ERROR: [BD 41-145] parameter s_axi_CTRL.AWUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.ARUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.WUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.RUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.BUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.ID_WIDTH not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.HAS_BURST not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.HAS_LOCK not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.HAS_CACHE not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.HAS_QOS not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.HAS_PROT not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.HAS_REGION not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.HAS_WSTRB not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.HAS_BRESP not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.HAS_RRESP not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.SUPPORTS_NARROW_BURST not found on block vsc
ERROR: [BD 41-145] parameter s_axi_CTRL.MAX_BURST_LENGTH not found on block vsc
ERROR: [BD 41-145] parameter s_axis_video.TDATA_NUM_BYTES not found on block vsc
ERROR: [BD 41-145] parameter s_axis_video.TUSER_WIDTH not found on block vsc
It seems that all the parameters of s_axi_CTRL, s_axis_video and m_axis_video failed. I have also tried to generate only the video processing subsystem but the same error appear. What could be the problem?
florentw
Hi @tcheeyon,
EDIT: This is a licensing issue which should be fixed in a future version. The solution is to use the license for the Test Pattern Generator IP which is provided for free.
Hope that helps,
Florent
florentw
Hi @tcheeyon,
Did you try to regenerate the BD output products after adding the VPSS license?
Could you check Report > Report IP status?
Florent
tcheeyon
Hi @florentw,
Thank you for replying. After I have added the video processing subsystem, I have tried closing the Vivado and deleting the project. Then regenerate a new project and block design. I have also checked the Report > Report IP status. I have attached the IP status in this message. As well as the VPSS generated on BD. As you can see, I am unable to generate the complete VPSS. The error and warning message is also attached in this message. Do you have any idea what did I miss out?
florentw
Hi @tcheeyon,
Could you try to close everything and create a new project with the video processing subsystem and see if you can configure it?
Florent
tcheeyon
Hi @florentw,
I have tried closing everything, create a new project, generate the VPSS (have the same error) then configure it. But I am unable to configure it.
florentw
Hi @tcheeyon,
This means that your license is not recognized by vivado.
Could you share a screenshot of Vivado license manager showing you license for the VPSS? Could you also show the columns "Host ID match" for this line?
Florent
tcheeyon
Hi @florentw,
I have attached the screenshot of Vivado license manager.
florentw
Hi @tcheeyon,
Hope that helps,
Florent
tcheeyon
Hi @florentw
I tried as you mentioned and now its working. Thank you.
mor2810
hey
i have the exact same error as you did.
can you help me solve it also ?
my license is valid, but i get the same error:
Please select 'Report IP Status' from the 'Tools/Report' menu or run Tcl command 'report_ip_status' for more information.
ERROR: [BD 41-145] Parameter s_axi_CTRL.AWUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.ARUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.WUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.RUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.BUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.ID_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.HAS_BURST not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.HAS_LOCK not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.HAS_CACHE not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.HAS_QOS not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.HAS_PROT not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.HAS_REGION not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.HAS_WSTRB not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.HAS_BRESP not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.HAS_RRESP not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.SUPPORTS_NARROW_BURST not found on block vsc
ERROR: [BD 41-145] Parameter s_axi_CTRL.MAX_BURST_LENGTH not found on block vsc
ERROR: [BD 41-145] Parameter s_axis_video.TDATA_NUM_BYTES not found on block vsc
ERROR: [BD 41-145] Parameter s_axis_video.TUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter s_axis_video.TID_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter s_axis_video.TDEST_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter s_axis_video.HAS_TREADY not found on block vsc
ERROR: [BD 41-145] Parameter s_axis_video.HAS_TSTRB not found on block vsc
ERROR: [BD 41-145] Parameter s_axis_video.HAS_TKEEP not found on block vsc
ERROR: [BD 41-145] Parameter s_axis_video.HAS_TLAST not found on block vsc
ERROR: [BD 41-145] Parameter m_axis_video.TDATA_NUM_BYTES not found on block vsc
ERROR: [BD 41-145] Parameter m_axis_video.TUSER_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter m_axis_video.TID_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter m_axis_video.TDEST_WIDTH not found on block vsc
ERROR: [BD 41-145] Parameter m_axis_video.HAS_TREADY not found on block vsc
ERROR: [BD 41-145] Parameter m_axis_video.HAS_TSTRB not found on block vsc
ERROR: [BD 41-145] Parameter m_axis_video.HAS_TKEEP not found on block vsc
ERROR: [BD 41-145] Parameter m_axis_video.HAS_TLAST not found on block vsc
ERROR: [Common 17-39] 'create_bd_cell' failed due to earlier errors.
CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file '/home/mor/Tools/Xilinx/Vivado/2018.1/data/ip/xilinx/v_proc_ss_v2_0/elaborate/bd.xit': ERROR: [Common 17-39] 'create_bd_cell' failed due to earlier errors.
ERROR: [IP_Flow 19-167] Failed to deliver one or more file(s).
ERROR: [IP_Flow 19-3541] IP Elaboration error: Failed to generate IP 'v_proc_ss_0'. Failed to generate 'Elaborate BD' outputs: Failed to elaborate IP.
florentw
Hi @mor2810
I mentioned in the thread, make sure you have a license for the Test Pattern Generator as well.
The recommendation is to use a version >2018.3 as there is no need for a license for those IPs.
If you still have issues with the TPG + VPSS licenses or with 2018.3/2019.1/2019.2... please create a new topic
Florent
