Example designs for Video Scaler and AXI stream switch
Is there any example designs for Xilinx Video Scaler (Scaler Only) and AXI Stream Switch IP?
Actually, I'm expecting designs involving either/both of the IPs.
Please let me know if any
Vinay
Vinay Shenoy
Hi @vinay_shenoy,
To get the source files into your SDK folder, please follow the directions in chapter 5 of PG235.
Step 16below is the step that adds the source files into your workspace.
2018-06-20 11_20_12-Xilinx Documentation Navigator 2017.2 -  http___www.xilinx.com_support_documenta.png
-Sam
Xilinx Video Design Hub
Hello @vinay_shenoy,
Yes, we do have such example design available.
Please refer XAPP1291 for more help.
Thank you.
Hi @kvasantr
Is there any similar design targeting ZCU102 development board?
Also, I am looking for HDMI TX only design with ready to use SDK application for ZCU102. Please let me know if any example designs are available.
Vinay
Vinay Shenoy
Please refer PG235. which is product guide for HDMI 1.4/2.0 TX Subsystem.
You will find elaborated steps under the same.
Thank you.
Hi @kvasantr
I have gone through the stuff as did exactly the same for generating HDMI TX only example design. I was able to generate and compile the example design. I was expecting sdk source to be there along with the design. I didn't any sdk application sources.
Vinay
Vinay Shenoy
Please refer chapter 5 of the PG235.
It does have steps to create the example design. you will get the SDK source through it.
Thank you
I refered the same and geenerated HDMI TX only design. I was able to recompile the same. Didn't find any source files inside sdk folder other than exported hardware platform.
Vinay
Vinay Shenoy
Hi @vinay_shenoy,
-Sam
