Explanation: The object was removed during the optimization process
I am a newbie to AccelDSP.  when I  " generate RTL"  , warring me "Explanation:The object was removed during the optimization process". then after 15 hours, it still unfinished. so it must have something wrong, please tell me what's wrong, and what should I do. thanks in advance.
You might want to try looking at the Fixed model first to see if that works, before you try implemenation.
Chris
Versal ACAP: AI Engines | Embedded SW Support
