08-15-2013 12:16 AM
Hey guys,
I'm using Virtex 5 70T.
In my design I need to use 3 FIRs. For each of them I'm using coefficients width of 32 bits because it gives me the best result.
The problem is it uses to many of the DSP48E slices.
I tried using less bits for the coefficients but the results I'm getting is not good to say the less.
In the attachments you can see the settings I use for the FIR.
Any suggestions?
Thanks a lot.
Assaf.
08-15-2013 07:14 AM - edited 08-15-2013 07:15 AM
What's your clock rate and sample rate? Setting the hardware oversampling period to 1 will give you a full parallel implementation (assuming your simulink system period is also set to 1). If you can oversample (i.e. use a faster clock than sample rate), resources will be shared and potentially save you a lot of DSP slices, depending on how much oversampling you can do.
