pb87
FSL bus connection?
Hello.
I want to use System Generator as a Pcore for Microblaze project in EDK.
I use From Register and To Register blocks to access Pcore from Microblaze and FSL bus to connect Pcore to Microblaze in EDK project.
The problem is: when i create my XPS project, I think the FSL links don't work...
Do you know if it exists tutorial to connect a core and a Microblaze with FSL? I've looked in the
Sysgen User Guide, but the connections are only with OPB... Do you have documents about this subject?
Thank you for your help!
