keshava7887
Failed to decode 8 h264 1920x1080p 30pfs using gstreamer.
I am trying to stream 8 h264  videos from laptop to zc106 evm board, and save them on hard-disk. I am using custom design for vcu without PL DDR.
I am able to build and run peta linux with gst-launch app. I have followed PG252 (v1.2) June 3, 2020 document for building process.
When I am trying to run below script I am encountering the following error please help in resolving it.
Script
gst-launch-1.0 udpsrc port=50000 buffer-size=60000000 caps="application/x-rtp, media=video, clock-rate=90000, payload=96, encoding-name=H264" ! rtpjitterbuffer latency=1000 ! queue ! rtph264depay ! h264parse ! omxh264dec low-latency=1 ! queue max-size-bytes=0 ! filesink location="multy_1.yuv" &
gst-launch-1.0 udpsrc port=50001 buffer-size=60000000 caps="application/x-rtp, media=video, clock-rate=90000, payload=96, encoding-name=H264" ! rtpjitterbuffer latency=1000 ! queue ! rtph264depay ! h264parse ! omxh264dec low-latency=1 ! queue max-size-bytes=0 ! filesink location="multy_2.yuv" &
gst-launch-1.0 udpsrc port=50002 buffer-size=60000000 caps="application/x-rtp, media=video, clock-rate=90000, payload=96, encoding-name=H264" ! rtpjitterbuffer latency=1000 ! queue ! rtph264depay ! h264parse ! omxh264dec low-latency=1 ! queue max-size-bytes=0 ! filesink location="multy_3.yuv" &
gst-launch-1.0 udpsrc port=50003 buffer-size=60000000 caps="application/x-rtp, media=video, clock-rate=90000, payload=96, encoding-name=H264" ! rtpjitterbuffer latency=1000 ! queue ! rtph264depay ! h264parse ! omxh264dec low-latency=1 ! queue max-size-bytes=0 ! filesink location="multy_4.yuv" &
gst-launch-1.0 udpsrc port=50004 buffer-size=60000000 caps="application/x-rtp, media=video, clock-rate=90000, payload=96, encoding-name=H264" ! rtpjitterbuffer latency=1000 ! queue ! rtph264depay ! h264parse ! omxh264dec low-latency=1 ! queue max-size-bytes=0 ! filesink location="multy_5.yuv" &
gst-launch-1.0 udpsrc port=50005 buffer-size=60000000 caps="application/x-rtp, media=video, clock-rate=90000, payload=96, encoding-name=H264" ! rtpjitterbuffer latency=1000 ! queue ! rtph264depay ! h264parse ! omxh264dec low-latency=1 ! queue max-size-bytes=0 ! filesink location="multy_6.yuv" &
gst-launch-1.0 udpsrc port=50006 buffer-size=60000000 caps="application/x-rtp, media=video, clock-rate=90000, payload=96, encoding-name=H264" ! rtpjitterbuffer latency=1000 ! queue ! rtph264depay ! h264parse ! omxh264dec low-latency=1 ! queue max-size-bytes=0 ! filesink location="multy_7.yuv" &
gst-launch-1.0 udpsrc port=50007 buffer-size=60000000 caps="application/x-rtp, media=video, clock-rate=90000, payload=96, encoding-name=H264" ! rtpjitterbuffer latency=1000 ! queue ! rtph264depay ! h264parse ! omxh264dec low-latency=1 ! queue max-size-bytes=0 ! filesink location="multy_8.yuv" &
Error
[ 731.552689] al5d a0120000.al5d: VCU: unavailable resources or wrong configuration
[ 731.560196] al5d a0120000.al5d: Channel wasn't created.
[2020-07-27 08:29:17.372117916] [module_dec.cpp:147] [EndDecoding[ 731.571316] al5d a0120000.al5d: VCU: unavailable resources or wrong configuration
] decoder: hardware doesn't have enough resources (142)
[ 731.581181] al5d a0120000.al5d: Channel wasn't created.
[2020-07-27 08:29:17.400253837] [module_dec.cpp:147] [EndDecoding] decoder: hardware doesn't have enough resources (142)
[2020-07-27 08:29:17.436531022] [omx_component.cpp:1830] [TreatSetStateCommand] OMX_ALG_ErrorChannelResourceUnavailable
ERROR: from element /GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec4: GStreamer encountered a general supporting library error.
Additional debug info:
../../git/omx/gstomxvideodec.c(2290): gst_omx_video_dec_loop (): /GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec4:
OpenMAX component in error state Component doesn't have enough hardware resources available to process the channel (0x90001001)
Execution ended after 0:00:12.932840264
Setting pipeline to PAUSED ...
Setting pipeline to READY ...
[2020-07-27 08:29:17.453770475] [omx_component.cpp:1830] [TreatSetStateCommand] OMX_ALG_ErrorChannelResourceUnavailable
[2020-07-27 08:29:17.637398222] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:17.637454398] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:17.637571520] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:17.637612444] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:17.790793339] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:17.790851015] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:17.790961966] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:17.791002520] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
Setting pipeline to NULL ...
[2020-07-27 08:29:18.113542727] [omx_component.cpp:428] [SendCommand] OMX_ErrorInvalidState
[2020-07-27 08:29:18.113643247] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:18.120462139] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:18.120622975] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:18.120672450] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:18.128741186] [omx_component.cpp:428] [SendCommand] OMX_ErrorInvalidState
[2020-07-27 08:29:18.128836095] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:18.135754787] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:18.135920303] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
[2020-07-27 08:29:18.135967168] [omx_component.cpp:830] [GetParameter] OMX_IndexParamPortDefinition: OMX_ErrorInvalidState
Keshava
florentw
HI @keshava7887
It seems that you do not have enough ressources.
Did you configure the VCU correctly in vivado (with 8 1080p30 streams)? This is the first thing I would check.
Then in case you are not already using 2020.1, I would recommend moving to it.
Finally, check the debugging section in the PG252 and see if there is anything which can help (for example increasing the cma size)
Florent
keshava7887
I am using petalinux 2020.1, we are not using PL DDR for VCU and I have configured VCU for 8 x 1080 30fps .  I default CMA size was set to 1024000kB.
I tried increasing CMA size by UBOOT command  'setenv bootargs ${bootargs} cma=1100M' and 'run bootcmd' to boot,
but linux failed with kernel panic.
I have tried increasing CMA values using
peta-linux : "petalinux-config -c kernel" refereed below link
 https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842546/Xilinx+Zynq+UltraScale+MPSoC+Video+Codec+Unit?view=blog
Device Drivers→Generic Driver options→ DMA Contiguous Memory Allocator
but I  could not find DMA Contiguous Memory Allocator option  in Device Drivers→Generic Driver options.
Please guide me in increasing CMA size to run 8 1080p streams.
Keshava murthy p
florentw
Hi @keshava7887
Did you try to do a search in the kernel config (using the key "/") to find the correct location for DMA Contiguous Memory Allocation setting?
As per pg252 you can also do the setting in u-boot using the bootarg
Florent
keshava7887
Hi Florentw,
Yes I have tried to  search in the kernel config (using the key "/") to find the correct location for DMA Contiguous Memory Allocation setting, but I didn't find anything.
In previous post, I had mentioned that Even I have used to set CMA to 1500MB in uboot using the command suggest by pg252
setenv bootargs ${bootargs} cma=1500M
but it failed to set . Can you suggest any alternative way to set it or point to other document which might help in resolving the issue.
Keshava murthy p
florentw
HI @keshava7887
The CMA configuration seems to have change location in the newer kernel. But you can find it by searching for CMA:
Florent
keshava7887
Hi Florentw,
I have tried the option which you have mentioned, but still in could not increase the CMA size.
Screenshot from 2020-08-07 20-05-41.pngScreenshot from 2020-08-07 20-06-03.png
Keshava murthy p
watari
Hi @keshava7887
I'd like to confirm your issue with linux boot up message.
Would you share boot up message to make sure how linux recognize reserved memory (cma setting) ?
Best regards,
florentw
HI @keshava7887
For you search for CMA, you are only displaying 2% of the search result. You need to read the full result to find what you are looking for...
Florent
