From Matlab coding to VHDL
Can we convert matlab code to VHDL? Or we have to do it in Simulink Block?
You can use AccelDSP to do this (for some Matlab code)
Cheers,
Martin
Martin Thompson
martin.j.thompson@trw.com
http://www.conekt.co.uk/capabilities/electronic-hardware
You can do this with Matlab Block in system Generator as well. But there are some restrictions for math operations - multiplying only by power of 2 and no division and for loops.
In my opinion SG generates good code for matlab only  if you need to have a lot of switch-case statements. If you have a lot of calculations then you have to control precision in matlab with special functions. Otherwise matlab maintains full precision and generates huge adders and substractors (like Fix50_20). In this case it is easier to control with standard SG blocks.
