kmwilliams
GetIncludeSubcores subcoreRepo Table is not filled
When I try to configure the xvprocss driver, instance (XVprocSs *) , the call to GetIncludeSubcores fails, within the call an entry is present (The IsPresent comes back true) but when I try to get the pointer back from subcoreRepo[...] there is no entry. I cannot find anywhere how this table is filled. Any help is greatly appreciated.
florentw
HI @kmwilliams,
Make sure you are following the exact same steps as the VPSS example design (in the same order):
  1. VprocSsConfigPtr = XVprocSs_LookupConfig(XPAR_V_PROC_SS_0_DEVICE_ID);
  2. status = XVprocSs_CfgInitialize(pVprocss, VprocSsConfigPtr, VprocSsConfigPtr->BaseAddress);
Also, did you fix the issue mentioned below?
https://forums.xilinx.com/t5/Video/Creating-xsdk-project-for-multiple-IP-HDMI-amp-VPSS-scaler/m-p/909643#M22632
The VPSS should be included directly in the BD. You will face too many issue by packaging it into a custom IP.
If you import the drivers manually you still do not have the xparameter.h not populated correctly
Florent
danielaragona
Thanks for your response. I should have been more explicit. I have 2 scalers, in the xparameters.h the addresses that were assigned to the scalers is backwards. Meaning in the design Scaler is assigned address 44a80000 and scaler1 is assigned 44cc0000 but in xparameters.h I see the opposite assignment. When the code gets to the point of the subcore table getting loaded it crashes.
florentw
Hi @danielaragona,
I am not sure the name in xparameter always match what you have in HW. The tool might check assign the ID 0 to the first vpss it can find. So I don't think this is an issue.
Can you try read in the first address for each VPSS in xsct (using mrd) to make sure you can access them.
Also, I just check: are you know using the VPSS directly in the BD or are you still using the VPSS in a packaged IP. If you are using them in a package IP, please try to use them directly.
Florent
danielaragona
I am now using them in a single BD.
I do the following...
1. In xhdmi_example.c main
XVprocSs VprocInst;
XVprocSs* pVpssPtr;
pVpssPtr = &pVprocInst:
XVprocSS_Config* VprocSsConfigPtr;
memset(pVprocss, 0, sizeof(XVprocSs)); //Does this belong here?
VprocSsConfigPtr = XVprocSs_LookupConfig(XPAR_SCALER_V_PROC_SS_0_DEVICE_ID);
status = XVprocSs_CfgInitialize(pVprocss,VprocSsConfigPtr,VprocSsConfigPtr->BaseAddress);
XSys_SetStreamParam(VpssPtr,
XSYS_VPSS_STREAM_IN,
1920,
1080,
XVIDC_CSF_RGB,
FALSE);
// Set VPSS Video Output AXI Stream
// Note that output video is always progressive
XSYS_VPSS_STREAM_OUT,
1920,
1080,
XVIDC_CSF_RGB,
FALSE);
XVprocSs_SetSubsystemConfig(pVpssPtr);
Seems to die in last call.
Do I need the memset? or is there another way to load?
Should the XVprocSs_SetSubsystemConfig(pVpssPtr); come before XSys_SetStreamParam?
