soc4video
Getting started with video for MPSOC - ZCU100/Ultra96
I'm getting started with video applications for MPSOC, I added video TPG and Video Frame Buffer Write and Concat  to Ultra96 BSP as show in attached block diagram.  I exported hdf file (attached) and generated attached dts files.  My goal is to create Video For Linux (V4L) device for V4L applications.
I noticed there are comments "/* This is a place holder node for a custom IP, user may need to update the entries */" in "pl.dtsi" file.
How should I make changes to "pl.dtsi" and other dts files to have TPG working (create "/dev/video0" under Linux for V4L applications?
It appears the are vcap_tpg (compatible = "xlnx,video") and dma specified in "pl.dtsi" of ZCU102 video reference design.
Is there guideline for creating dts files for video for MPSOC?  i.e.,
(1). Should I copy vcap_tpg node from ZCU102 to Ultra96 "pl.dtsi"?
(2). The "v_frmbuf_wr-2.1' IP in "pl.dtsi" does not have DMA specified, how should I add DMA parameters to it?
Thanks in advance.
Tags (2)
soc4video
I added vcap and dma parameters to "pl.dtsi" (attached) but got errors :
[ 1.422255] xilinx-video amba_pl@0:vcap_tpg: /amba_pl@0/vcap_tpg/ports/port@0 initialization failed
[ 1.422268] xilinx-video amba_pl@0:vcap_tpg: DMA initialization failed
[ 1.423019] xilinx-tpg 80010000.v_tpg: invalid format in DT
[ 1.423033] xilinx-tpg: probe of 80010000.v_tpg failed with error -22
hokim
I have succeeded in implementing tpg on ultra96
The results are attached
soc4video
@hokim,
I was able to create/build Vivado project using your files. I exported hdf file, created dts files using hsi, included your "system_user.dtsi" and built system-top.dtb file.
I created new BOOT.BIN with new bit file.
My Ultra96 hang half way during kernel loading without error.
The serial console at J6 header stopped at "Starting kernel ...", the DP display stopped at "ALSA device list:"
I suspect my new dtb doesn't match with new bit file.
Could you send me your BOOT.BIN, Image and system-top.dtb?
soc4video
@hoki94
Your files worked with your rootfs and my rootfs.  I have /dev/video0, /dev/video1 and /dev/video2 created and I can use "v4l2-ctl -all" to list information of all 3 video devices.
I have not used TPG software before, how do you test Xilinx TPG from Linux?
soc4video
Where can I find documentations on how to use Xilinx video pipelines in Linux?
florentw
Hi @soc4video,
Do you have any updates on this? Was @hokim's reply enough for you?
If your question is answered or your issue is solved, please mark the response which helped as solution (click on the button "Accept as solution" below the reply)
Best Regards,
Florent
