apierp
Grayscale TPG
I was wondering if it is possible to transform the TPG from Florentw's video series tutorial to grayscale...i.e. only 8 bits per pixel to indicate intensity instead of rbg_8. I am struggling to understand how this would work.
Thanks!
florentw
Hi @apierp
The solution from @drjohnsmith is the correct one. But the Xilinx TPG IP can be used directly in YUV (instead of RGB). So no need to convert. Only configure it in YUV and take the 8 bits lSB
Florent
drjohnsmith
convert RGB to Luma / chroma, and only take the Luma.
florentw
Hi @apierp
Florent
drjohnsmith
@florentw
OOPs, forgot abotuy the YUV mode of the TPG,
much more logical,
If I could Kudo you, I would .
florentw
HI @apierp
Do you have any update on this topic? Is everything clear for you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
