tim_severance
HDCP EEPROM Programming Reading not working
   I just generated an HDMI TX Only example design with HDCP 1.4 and 2.2 using Vivado 2018.1 and implemented it, and in SDK generated the hdcp_key_utility and TxOnly_Microblaze applications to be used on a KC-705 board which has an Inrevium FMC-HDMI4K card on it for HDMI.
   It seems that the FMC board has an EDID EEPROM which the HDCP application uses for storing the keys (Device ID 0x50 7 bit address or 0xA0 8 bit address with LSB as read bit).
   When I run the hdcp_key_utility to load the keys and set a password I get the output shown below.
   But when I then run the TxOnly_Microblaze application and re-enter the password to read the keys it doesn't like the password.   Am I doing this correctly?
Tim
tim_severance
@watari,
    I looked at the io pin mapping and verified the FMC IIC pins go to the FMC board and those nets go to that I2C eeprom labeled for "EDID", but since I am doing HDMI Tx only I can use it for HDCP.
    I think I got it working after trying a few more times.   I think there might be an issue with my TeraTerm terminal adding in characters sometimes.
Tim
watari
Hi @tim_severance
I'm not sure. Because of I only have an experience of HDCP with Displayport at KC-705 and this daughter board.
In this case I stored HDCP key in EEPROM on KC-705.
I guess  it's a same situation.
So FMC has an EEPROM for EDID not for HDCP.
Would you make sure it ?
Best regards,
tim_severance
@watari,
Tim
florentw
HI @tim_severance,
Is everything working fine for you now?
I yes, could you kindly mark the topic as solved? Else, as usual, let us know, we are here to help ;)
Florent
