ziladdev
HDMI/DVI RX on Zynq Ultrascale MPSOC
Dear Experts,
We are investigating the use of the Xilinx MPSoC Ultrascaler to receive up to 3 HDMI sources. The IP core available seems to be the PG236 and this works well in the example design of the ZCU102. However, in our application limited to the use of ZU3EG, for this we see that video PHY IP cannot be used.
How can we receive HDMI on this device? If not, is there a workaround by adding
How many HDMI video sources can be received? which device allows up to 3 channels?
Any help is most welcome
Tags (2)
samk
Hi @ziladdev,
Were watari and florentw able to answer your question?
If anything was missed, please reply so that we can comment. If not, can you select one of their responses as the solution?
Thank you,
Sam
Xilinx Video Design Hub
watari
Hi @ziladdev
What are your target resolution, framerate and pixel clock frequency ?
Best regards,
ziladdev
The maximum is 1080p 60Hz. But we are flexible on this, i.e. it could be lower.
watari
Hi @ziladdev
You can achive your target with TMDS, SelectIO, decoder and EDID (without Xilinx HDMI Rx IP).
https://www.xilinx.com/support/documentation/user_guides/ug571-ultrascale-selectio.pdf
Also I suggest you to refer Digilent's DVI2RGB IP, too.
https://github.com/Digilent/vivado-library/tree/master/ip/dvi2rgb
[Note]
I suggest you to consider lower pixel clock, if you are facing SI issue.
Best regards,
florentw
HI @ziladdev
Just to add a bit on the really good answer from @watari (it deserve a kudos and to be marked as solution ;) ), Xilinx has an old xapp (xapp495) which is showing HDMI/DVI on TMDS interface. This is for Spartan-6 but could be adapted to Ultrascale+ as the code is fully available.
And another solution is potentially to have an external device managing the HDMI/DVI interface as the ADV7611. But you would need to add 3 of them on your PCB. You might want to refer to this blog which is using it.
Florent
ziladdev
Hold your horses....Ultrascale+ has no support for TMDS or am I mistaken here?
TMDS only availble on HR banks (according to UG571)...ZU+ has only HD and HP (Table 1-3 of ug1075). Please explain!
You gotta work harder to earn that Kudos :).
florentw
Hi @ziladdev
Yes you are right, I forgot about it while I already answered this in a previous topic:
https://forums.xilinx.com/t5/Versal-and-UltraScale/TMDS-on-ZU/m-p/916441/highlight/true#M8012
So as per this topic, you can use the xapp and then change the voltage level externally to complly with the HDMI spec.
Or you can use an external device as the ADV7611.
Florent
watari
Hi @ziladdev
Would you consider TMDS redriver and AC-coupled signal by receiving LVDS buffer on FPGA ?
Best regards,
ziladdev
That sounds as a magic solution. Which IO bank should we use and what IO standard ? as TMDS_33 is unavailble...
I will look more closely into the xapp and get back to you.
watari
Hi @ziladdev
You can use both bank. Also, I already mentioned before about IO buffet type.
Best regards,
samk
Hi @ziladdev,
Thank you,
Sam
