darshan007
HDMI Display not working for Ultra96V2 board
Hi Team,
Actually, my Ultra 96 v2 board is not able to connect to the Display monitor. I had tested with Active and Passive Mini-DP to HDMI Converter, but it is not working. I had also tested with 2 HDMI Monitors, but still the same.
I am using DPU Image for the Ultra96v2 board.
Can anyone help me to resolve this issue? Would be a great help from your side.
Darshan
florentw
Hi @darshan007
Adapters are not supported by Xilinx. Passive adapters will not work for sure as the Displayport controller of the ZU+ does not support DP++.
Active adapters might work but it is up to the users to characterize the adaptors to make sure they work or not. Refer to AR#54514
You can try to run the modetest command with the active adatpter. If you can see information from the monitor like EDID and supported resolution then there is some hope. Else this probably mean that the active adaptor you have will not work.
The best for you is still to use a Displayport monitor
Florent
