sitting
HDMI TX ip problem
When I connect to HDMI TX of ZCU104, some 4K monitors can not display directly until I press "C" to force output colorbar.
I find these monitors doesn't support SCDC Read Request, so the HDMI TX ip can not work.
A part of SCDC read request code as below:
Is there any way to solve this problem ?
Sitting
Tags (2)
xud
Hi @sitting
Can you provide a list of monitor model types and HDMI TX xci, please? I will see if I can reproduce the issue.
sitting
Hi @xud,
Here are the monitor list:
1. ViewSonic vp2780-4k
2. HP Z32s
The attached is TX xci file.
Sitting
xud
Hi @sitting
I have tested on ZCU104 board just now. I notice TX Stream is down for 4 times before it becomes stable. See attached log file.
But I don't need to type "c" to force it to color BAR mode.
When you see the issue, can you type "i" and "z", and then send the terminal log file please?
sitting
Hi @xud,
I can't reproduce this issue , HDMI TX works fine now.
Sitting
florentw
Hi @sitting,
If it is working for you now, could you kindly close the topic by marking a reply as accepted solution?
Thanks and Regards,
Florent
