In my design, the HDMI Tx is configured in AXI-Stream input mode.  The axis_aclk runs at 300MHz and the video clock comes from the board, for example 148,5MHz.
With this configuration, what should I expect the axis_tuser on the video-in AXI-Stream (the start of frame) to look like?  will the tuser pulses (qualified with tvalid and tready) be stable and equi-distant, meaning with the same number of axis_aclk between them?  I am relying on tuser to be stable and locked for another module.  Will that work?
Jacques
Tags (2)
@jmcm
If you want to count the cycles between tuser, you need to check the valid cycle (both tvalid and tready are asserted). The valid cycles between 2 tuser pulse should be the same as active frame size/ppc.
@jmcm
Thanks.  This answers my question.
Jacques
